Hi!
I'm trying to find the "advanced" button for the email integration, but can't find it in the top right corner which is where this page https://support.atlassian.com/opsgenie/docs/use-advanced-integration-settings/ implies it should be.
I'm currently on the essentials plan. Is this a feature of a higher plan?
Hmmm... That's not clear anywhere.
https://www.atlassian.com/software/opsgenie/pricing#Features
Even the comparison chart doesn't make that clear.
Thank you!
Hi @Jonathan Tan ,
The advanced tab would be related to these sections of the pricing page:
The advanced tab allows you to customize which requests create alerts, while also the flexibility to customize how the alerts are formatted / sent to your users.
