Disable bi-directional intigration between Opsgenie and Jira Service
Shashi Reddy
July 14, 2022
When I create an Opsgenie Alert through email integration, I do not want that to create a jira ticket. How do I disable this feature?
Darryl Lee
July 14, 2022
Hi @Shashi Reddy,
This is Darryl. I am here to help. 😃
Solution
Because every alert created by Email integration will have 1 property:
"Source": "Email"
So you may adjust the Alert Filter on your Jira integration like this:
"Match all conditions below"
"Source" | "NOT" | "Contains" | "Email"
In this way, every alert created by Email integration will not be pushed to your Jira to create tickets.
Hope this helps.
Darryl Lee
Support Engineer, Atlassian
Shashi Reddy
July 15, 2022
Hi Darryl,
I would like to have the Jira integration be one-directional, When a user creates a Jira ticket, an Opsgenie alert would be created automatically, and that is working as expected.
But the other way round, I never want a Jira ticket to be created when an Opsgenie alert is created via email or any other source. This option was actually unchecked so the Jira ticket is never created.
Based on your suggestion I have enabled it with the Alert filter, but that too did not help.
