×Hello
We have create a group hunt on MIcrosoft teams with a french phone number
When our client try to call a help desk number; it should be redirected via Opsgenie to our phone number
It rings but when we accept the call nothing happen from our side
From client side; the call is hang out without any msg
Could you plz help us to understand more what happen
Thank you
Hello there,
Thank you for contacting the Opsgenie community.
To address the issue you're experiencing with call redirection via Opsgenie, here are a few steps and considerations that might help resolve the problem:
Alert Logs: Review the alert activity logs in Opsgenie to identify any specific issues with call handling. This can provide insights into whether calls are being hung up by the caller or if there are connectivity issues on the recipient's side.
Twilio Support: If you are using a custom phone number from Twilio, consider reaching out to Twilio support.
By following these steps, you should be able to identify and resolve the issue with call redirection. If the problem persists, consider contacting us on Opsgenie support for further assistance.
I hope the above helps.
Nayan
