Hi @Jugal.Shroff,
Using the examples in our Regex doc, you can try the following for tag1 and tag2:
For Tag1: {{message.extract(/tun-(\S+)\-.*\-\"(\S+)\"-.*/, 1)}}
For Tag2: {{message.extract(/tun-(\S+)\-.*\-\"(\S+)\"-.*/, 2)}}
In the example text you gave, I am assuming the word "tun-" and the dashes following are "static".
The other option to try would be:
For Tag1: {{message.extract(/tun-(\S+)\-.*\-\"\S+\"-.*/)}}
For Tag2: {{message.extract(/tun-\S+\-.*\-\"(\S+)\"-.*/)}}
You can test the 2nd method in regex101.com as well, for example:
This is how I had tested:
Hope the above point you in the right direction. All the best!
Thanks for your help. Its not workking for me.
I want to tag details after tun-thiswillchange with new alert (my first tag)-xxx(not static)-thiswillchange with new alert (my second tag)-xxx(not static)-xxx(not static)
my second tag contents charector and number combination minimum 2 and maximum 3 charector and number combinations
