Is a terraform resource for Slack-Opsgenie integration?
Pranita Thatichetla September 2, 2022
Hi , I was looking for terraform resource for Slack-Opsgenie integration under https://registry.terraform.io/providers/opsgenie/opsgenie/latest/docs however could not find anything for Slack integration.
The integration resource that you have opsgenie-api-integration does not support 'slack' under the argument type list.
I am trying to configure slack integration via terraform
Is there any way you can point me to the right direction or provide some details.
Thanks.
John M
September 4, 2022 edited
Hi @Pranita Thatichetla
I don't think there is Terraform support for slack integrations. Our documentation specifies that Terraform only creates and manages resources for API and email-based integrations. This is from Opsgenie's Terraform document:
Capabilities
Opsgenie Terraform provider creates and manages the following resources with Terraform.
  • Users (without User Contact API),
  • Teams (with or without members),
  • API and Email Based Integrations
  • Escalations
  • Schedules
  • Schedule Rotations
Pranita Thatichetla September 7, 2022
Hi John ,
Thank you for your response. When we try to set up a Slack integration , it generates an API key. The following is from https://support.atlassian.com/opsgenie/docs/integrate-opsgenie-with-slack-app/
so I am assuming Slack integration is done using API keys, however in the Opsgenie Terraform provider - opsgenie-api-integration , for the argument type ,  the list of arguments  does not have Slack listed : https://support.atlassian.com/opsgenie/docs/integration-types-to-be-used-with-the-api/
John M
September 7, 2022
Hi @Pranita Thatichetla ,
The reason Slack isn't on that list is that to set up the slack integration you must go through the Oauth screens directly from Opsgenie to grant access - something that can't be done via API.
Pranita Thatichetla September 10, 2022
Thank you for your response @John M
Like • John M likes this
