×Hello,
I'm trying to attach a report to an alert using a command similar to this one:
`./opsgenie-lamp_v3.1.4 attachFile --id "alias123" --identifier alias --fileName report.html --apiKey 123 --filePath .`
But I'm getting this message:
2024/04/19 16:30:42 INFO: Logging to file is disabled, To enable Logging to file Please specify logPath in configuration
INFO[2024-04-19T16:30:42.442047-03:00] Client is configured with ApiUrl: api.opsgenie.com, LogLevel: info, RetryMaxCount: 4
ERRO[2024-04-19T16:30:42.95022-03:00] Error occurred with Status code: 413, Message: Current request is not a multipart request, Took: 0.001000, RequestId: 867cd55a-75ac-4cc0-b59f-524757d80c22
2024/04/19 16:30:42 ERROR : Error occurred with Status code: 413, Message: Current request is not a multipart request, Took: 0.001000, RequestId: 867cd55a-75ac-4cc0-b59f-524757d80c22
Did I miss something or am I doing something wrong?
Hi @Marcos Alano ,
It looks like the attachment may exceed the file size limit of 2 MB. can you try again with a file that is under 2 MB?
https://support.atlassian.com/opsgenie/docs/add-a-note-or-attachment-to-an-alert/#Add-Attachments
I will accept your answer, but I found the problem. The file I was trying to upload had a typo, so virtually the file didn't exist. But thank you. Maybe improve the error message for edge cases, like missing file and file two big?
Thanks for confirming and for posting your solution, @Marcos Alano
