v2/alerts/requests/ returning 404
Joel Bradley
So recently my requests sent to https://api.opsgenie.com/v2/alerts/requests/ are returning 404 errors.
If I don't include the authorization header I get could not authenticate, requests I send to https://api.opsgenie.com/v2/alerts/ work fine, and it worked okay last week.
No valid request id is working.
var uri = $"https://api.opsgenie.com/v2/alerts/requests/{requestId}";
client.Headers.Add(HttpRequestHeader.Authorization, genieKey);
request = client.DownloadString(uri);
I'm not sure what I'm doing wrong.
Connor Eyles
December 30, 2021
Hi @Joel Bradley
Thanks for reaching out!
So in relation to this REST call https://docs.opsgenie.com/docs/alert-api#get-request-status
The Get Request Status endpoint is used to track the status and alert details (if any) of the request whose identifier is given.
I would like to point out I am not a C# specialist but in best efforts provide some information that may help you with your troubleshooting here. What I can do is share an example for this request using C# - RestSharp
using RestSharp;
using RestSharp.Authenticators;
var client = new RestClient("https://api.opsgenie.com/v2/alerts/requests/913fb485-2a30-4b03-b9cb-6207599669d9");
client.Timeout = -1;
var request = new RestRequest(Method.GET);
request.AddHeader("Authorization", "GenieKey eb243592-faa2-4ba2-a551q-1afdf565c889");
IRestResponse response = client.Execute(request);
Console.WriteLine(response.Content);
Something I have noticed from your code is that your genieKey is not enclosed with "" like it is in my example code. You could try that and see if it works on your end!
Let me know how you go with this one or have any follow up questions.
Connor
