×Quick one, does unclaiming users and removing the domain (will be re-added and will use a different verification method) kick out org admins too? Is the data in Atlassian going to be intact after removing and re-adding the domain?
Hi @Japs Almasol Removing a claimed domain in Atlassian Access will remove any security options you applied to those managed accounts.
The accounts in this domain will no longer be managed. You will no longer be able to apply a verification method in that case.
If the purpose is to apply a different verification method, remove SSO and 2FA from the current managed accounts without removing the domain verification.
