Hmm... we're having trouble logging you in. You'll need to talk to your organization admin - tell them we sent you, and that there appears to be an issue with the SAML public key used for your SAML single sign-on configuration.
The error you notice is due to an incorrect certificate uploaded to SAML configuration at Atlassian organization.
For the next attempt to configure SAML, please make sure the certificate downloaded from Azure is the correct certificate before uploading to SAML configuration.
One of the ways to ensure the certificate is by decoding the certificate here: https://www.sslshopper.com/certificate-decoder.html and confirming it displays:
Jayant
I'm having this same issue and the certificate is correct.
Any idea?
Dani
Disabled SAML in Azure and could login again.
