×The REST API calls with query parameter `to` and `from` does not return any results for the events endpoint (/admin/v1/orgs/{orgId}/events).
The API documentation does mention these parameters and I would like to use them to filter events. (https://developer.atlassian.com/cloud/admin/organization/rest/api-group-orgs/#api-orgs-orgid-events-get)
I am using `curl` to query the results. The query calls for me looks as shown below. The date and time are provided in the Unix timestamp format.
curl --request GET --url 'https://api.atlassian.com/admin/v1/orgs/{orgId}/events?from=1634642484&to=1634828884' --header 'Authorization: Bearer <API-Key>'
There are events generated in this time interval but the API call shows no results. Could you look into it and let me know if I am doing something wrong?
This is what I see as output. It does not show any error. I am using an account with the trial plan for testing.
{"data":[],"links":{},"meta":{"attributes":null,"next":null,"prev":null,"page_size":30,"start_index":null,"end_index":null,"total":0}}
just add three more zeros to your epoch time and it will start working. stupid documentation.
Hi @kumarak
It seems that you do not have any events yet in your organization. Make actions in your organization by adding users to groups, creating a new user, etc.
Hi @Prince Nyeche , Thanks for the reply. I have events generated with the organization.
Should the Unix timestamp be in milliseconds? The document does not mention anything about it but it does work for me on using timestamps in milliseconds.
Hi @kumarak
I'm not sure about that but if it works for you that's great.
