gsuite integration does not give access to confluence
Mirko Schmidt February 5, 2021
Hi there,
My org uses gsuite integration to manage users.
"All users from G Suite" is added in the settings/"product access" page to both products: Jira Software and Confluence.
Problem: New users do not get access to confluence. (But they do get access to Jira software.)
I tried to disable and re-enable gsuite linking, but had no success.
I can fix the issue on a per-user basis by adding new users manually to the "confluence-users" group, but that's causing extra work for every new user.
Can you please let me know how to fix gsuite integration?
Angélica Luz
February 8, 2021
Hello @Mirko Schmidt,
Just for a better understanding of the issue, I would like to know if Confluence is enabled on Product Access and if you tried to disabled/enabled it again.
Is it happening since you first integrated your site with GSuite or it started happening after a while?
Does it show any error while or after syncing with GSuite? If it does, please share a screenshot with us (just make sure to hide private information).
Angélica
Mirko Schmidt February 8, 2021 edited
Hi @Angélica Luz ,
Yes, Confluence is enabled on the product access page.
Yes, I tried to disable / enable it multiple times with no success.
I think this is happening since I integrated with GSuite. It was never working properly.
I don't see an error popping up. Also, the log file doesn't show anything.
Is there any other place where I could check for additional information?
Angélica Luz
February 9, 2021
Thank you for the details, @Mirko Schmidt.
Further investigating this issue, there is one thing that can prevent new users from getting access to Confluence: Space Permissions.
They are not automatically added when GSuite adds them to “All users from GSuite” group, but it works when you add manually the “confluence-users” group because, by default, this group has permissions.
Can you please go to Confluence and click on Cog icon > Space permissions?
On this page, click on Edit permissions and grant permission to “All users from GSuite” > Save.
Please, take your time to test and let us know how it goes.
Mirko Schmidt February 9, 2021
Hi @Angélica Luz ,
Ah, that sounds reasonable. I changed the default space permissions for new spaces as well as the space permissions for all existing spaces using your advice.
I'll report back once I've added the next user.
Mirko
Like Angélica Luz likes this
