when External User Policy is enabled, is there a way to enable the mobile app access to them?
miguel.yoshida November 13, 2023 edited
"When these settings are on, we block external users from accessing your organization with mobile apps. We do this to protect your data."
Is there a way to change this?
Joseph Chung Yin
@miguel.yoshida -
Take a look at the following reference link to see if it can assist you on mobile access - https://support.atlassian.com/security-and-access-policies/docs/mobile-policy-mam-security-controls-and-supported-apps/
Don't know if can help you or not.  I would recommend that you should contact Atlassian Support (https;//support.atlassian.com) for further assistance.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
Joseph Chung Yin
@miguel.yoshida -
If my suggestion helped you, please click on "Accept answer" when you have a chance, so others with similar asks will see this post as an answered one.
Best, Joseph
Kian Stack Mumo Systems
@miguel.yoshida
It does not appear so. I can't see that as an option to configure in Access.
