Using Rovo to create a Confluence page via automation
Robert Nichols
So I've created a Rovo Agent which at the end is told to create a Confluence page in a certain location.
When I run this manually it asks for verification before creating the page.
If I call this from an automation then I'm hoping that I can get the Rovo agent to create the page without verification. At the moment the Automation just gets the Rovo response as a variable.
The Rovo agent has the required permissions and appropriate actions applied.
Am I trying to do something which is currently impossible ?
Upasna Bassi
When you run the agent, the AI response gets stored in the variable {{agentResponse}}.
You’ll just need to add one more step after the Rovo agent runs. Choose the action called "Publish new page"
  1.  Set up the Page title however you like.
  2.  In the Page body, simply drop in the {{agentResponse}} variable.
Interesting use-case! I just tried this out and it worked perfectly! Here’s a screenshot to show what the setup looks like.
Rawlo Smith June 20, 2025
I would like to update the contents of a page rather than create a new page every time.  Rovo has "edit page" as an available action and if I interact with the agent using that action directly, it will append content to a page (after I hit confirm).
Edit page is not available as an action in automation so hoping to get the Agent to do it but it won't.  I tried adding a line in the instructions to not ask for confirmation but interacting directly with the Agent it still asks me for confirmation and if I run it as part of automation, doe does not update confluence so wondering if it still trying to ask for confirmation when run from automation and fails to execute the action because there is no confirmation.
Like KINAY Mizuho_Ricksoft_ likes this
Aaron Haydon
Unfortunately Rovo Agents wont use Actions available to them during a automation
