×Hello everyone!
I turned on Statuspage to test it and learn its functioning, but I do not longer need it.
How could I delete it from my subscriptions page? There's no way to turn it off?
THX!
Hey Juan,
Thanks for reaching out to Atlassian Community!
Please follow the steps described here - https://support.atlassian.com/statuspage/docs/delete-a-page-or-organization/
In case you're still having issues, please feel free to raise it with us.
Best Regards,
Egor
@Juan Carlos Pin Did you check the following link: https://support.atlassian.com/statuspage/docs/enable-subscribers/ ?
Nicolas
Could you please mark the answer as accepted if you agreed ?
Hi @Nicolas Grossi The point is that there's nobody subscripted to it. I just need to remove it from my products :)
THX
