hi there,
I see that the status page can be localized using "Localize". Unfortunately, we do not use this app.
Are there any plans to include "Lokalise" (Spelled with an "s") as an App for translations/localizations as well?
Are there any other ways to localize the page, without using Localize? Thank you!
Hello @katharina_volkmann ,
I'm from the Statuspage support and here to help! :)
Unfortunately, we currently support using only the localize app for translation.
Alternatively, you can use the custom HTML on a page and the language shown would be the same as the one being used in your HTML code.
Best,
Shashwat
ok, thanks! I will look into that.
Is there a process to submit this as a feature request? :)
Thank you :)
I have raised the Feature Request number: STATUS-699 for this feature.
As these feature requests are not yet public, I would request you to log a ticket with us using this link, to check the status and updates on the same.
Best,
Shashwat
My pleasure, have a great day ahead!
