×How do I send an incident notification for a historical incident to email subscribers? The problem is that I am not able to mark components for past incidents and subscribers are subscribed to components. What's the recommendation for this?
Hi @Khoi Do -
There currently isn't a direct way to send notifications for backfilled incidents since you can't choose impacted components. As a workaround, you can create a regular incident, add impacted components and inform the subscribers that this is for a past incident.
Hope this helps!
