Copied the Question from another forum but is similar in concept.
Original Link: https://community.atlassian.com/t5/Statuspage-questions/can-we-change-the-name-of-status-of-component-on-statuspage/qaq-p/2024117
I copied the script and it works for changing all status on all components, but want one component to be one set of information (On Time, Slightly Delayed, and Major Delayed) and then have the other component be "Not Ready" and "Ready". I've attempted to do this several different ways but am unable to do so.
Hey @CMillard ,
Thanks for reaching out to the Statuspage Community. What sort of issues are you running into? Support doesn't have any specific code to do this but it might help if you share part of your code.
I think it might not be working because the statuses apply to all components and I don't think there is a way to give different components a different number of corresponding statuses.
Best,
Abraham, Statuspage Support
