I'm using the Slack integration support to send statuspage.io alerts to certain slack channels depending on the component impacted. There is an option to filter by component but it doesn't seem to work. An incident to ANY component would trigger an alert to the slack channel.
Is this a known bug? Has anyone else run into it?
Hey there!
I have gone over this integration do you have the Incidents tick box ticked?
If you have this ticked you will receive notifications on all incidents to this channel.
If you are wanting to receive notifications just on the affected component, leave just the Components tick box ticked.
Connor
No problems @Khoi Do
Let me know if this work for you :)
Glad to hear 😊
