Automation of dates on checklist elements and cards
Joanna Czajkowska
February 11, 2022
I have a board, where each card is a separate task, but there's also one card called "SCHEDULE" with a checklist of all tasks (it's necessary because there are also some small tasks that don't require separate cards). Some of the checklist elements concern cards with the same name.
For example:TRELLO1.JPG TRELLO2.JPG
I'd like to make automation, so if the due date is set for the list element called "TASK 2", the date on the card with the same name ("TASK 2") is set for the same due date.
And the same for marking the date as completed.
Is it possible to do so?
milynnus
February 11, 2022 edited
@Joanna Czajkowska
Reading your post again, can I know which direction for the  update. Is it when you update an item due date you want the corresponding card due date to be updated or the reverse order.
