Whenever I open a card, I can't use the Card Repeat because the Card Repeater button doesn't show up even though I have the power-up enabled.
Welcome @Eli Samovski
Which browser are you using? Have you cleared your cache and tried in the incognito mode?
I tried clearing Cache, looks like it just takes a bit to load along with the rest of the power ups. I have used both Chrome and Brave Browser to open the site.
@Eli Samovski , I understand. How is the performance going now? Are you having a decent internet connection? Are there more processes running that are slowing down and possibly eating your RAM and processor power?
I'm having this same issue, and your suggestions are not working. I am using a modern laptop with plenty of power. How much power do these power ups need? I did find that this comes and goes so it is sporadic in nature.
This sounds more like a lazy programmer not regression testing code change. I may sound cynical but I'm in the business and very saddened by the state of affair in our industry.
Can you please expedite this issue? I use this power up extensively and I am not able to work as usual until it is fixed.
Also, I just tried this on Chrome instead of Edge and it works.
Thanks much,
Michael
