Custom Fields Missing and File Sharing Flow
kimcyte
August 28, 2025
I am experiencing a couple of issues with Trello and would like your assistance:
  1. Custom Fields Missing:
    The custom fields that I had previously set to display on the front of my cards have disappeared across all of my boards. Could you please advise how to fix this? Will the custom fields I created before be restored, or do I need to set them up again?
  2. File Sharing Flow:
    When sharing files from other apps to Trello, I always have to re-select the board, list, and card (new or existing) every single time. There doesn’t seem to be an option to use my most recent sharing destination, which makes sharing multiple files time-consuming. Is there a way to keep or remember my last-used sharing settings, or can this be improved in future updates?
I would appreciate your guidance on how to resolve or improve these issues.
Thank you for your support.
Gaurav Kataria
August 29, 2025
1. Custom Fields is a paid feature, so it is possible that custom fields disappeared after the Premium Free Trial ended.
2. There are a number of quick capture methods in Trello, e.g., Slack, Microsoft Teams, Email, iOS, Android widgets, etc. All of those directly send the captured content to your Inbox by default (i.e. you don't have to select it every time) https://support.atlassian.com/trello/docs/trello-inbox/
FREE
