You cannot use the label id as your idModel.
Thanks for your response. what should be the modelId to listen to this action "Label added to Card"
@Rathna you should be watching for changes on the board so use the board id as the idModel.
Id Model can only be boardId, listId or cardId
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗
