×How can I fix text reports to show proper formatting?
I have created a report in Trello Butler which sends it to Slack (Trello and Slack are integrated).
Markdown formatting for named links, bold text, and bullet points is not performed on the report (e.g., **Report End** shows up as **Report End**, not bold text).
Thanks for the help!
Trello formatting instructions I relied on for named links, bold text, and bullet points:
The Trello Butler report:
Thank you, i have the same problem. Have you found a solution?
