How to use calendar
Natalia Zmachinskaya January 2, 2023 edited
Hi all! Can you please explain how i can use calendar with Trello (free account)? i'm happy with trello but desperate to have calendar now and will be 100% content) what is the major difference between add on calendar in free version and power up in paid one? thanks!
Alex Koxaras _Relational_
Hi @Natalia Zmachinskaya and welcome to the community!
Trello calendar view is available only with Premium and Enterprise plans. You can read more about it here https://blog.trello.com/trello-calendar-view
In order to see the differences between the built-in calendar view that trello offers and all the calendar power-ups, you have to compare them side by side. Some of them might offer more capabilities than the ones offered by trello.
But the thing is that is you are already on a premium trello plan, then perhaps there is no need to buy a calendar power-up.
Natalia Zmachinskaya January 3, 2023
hi @Alex Koxaras _Relational_ and thanks for the detailed reply! yes, i'm studying the calendar now and it is great there's one )) it means i dont have to switch to a another task tracker (i'm with trello for over 10 years i think)) do you if it's possible to add a shortcut to the calendar directly when entering app on android? would be another great thing to have)
