×Hi @Antonia
You can customize the fields visible on the cards under the three dots -> configure views -> cards layout, and add the creator field:
I hope it will be helpful :)
Kind Regards,
Weronika
Hi @Antonia
Since this is the Jira Service Management board, no. Alternatively, you can create a filter in Jira that will be based on the JSM project, then you can edit the Card layout to show the Reporter.
