When pushing out csv reports from Trello, is there a way to: 1) order labels for sake of consistency/reduce cumbersome edits to the spreadsheet once generated (ie, I should be able to just split the cell results into 3 separate columns for each of the 3 labels I'm using without any further manipulation/preparation of the data); and 2) to remove the color descriptors from the output? I'd rather have setting in Trello than have to fiddle in excel, etc. I've tried playing with the order of labeling, but that doesn't seem to make a difference as they are alphabetical but our labeling system incorporates many names, making alphabetical ordering useless.
Hi Ceylan! Welcome to Trello community!
I'm afraid there isn't a way to customize that when exporting CSV files from Trello. Once the file is exported you can customize and make editions direct on a spreadsheet app.
Rather than that, there are some 3rd party Power-ups you can explore that export boards, maybe one of them would suit your needs. I'm not familiar with them as they are developed and managed by other companies outside Trello, but you can check the options here: https://trello.com/power-ups/search?q=export
