Template and Autmation
Craig Lemberger February 10, 2025
Hello All,
I've created a template board with specific automations.  After creating a new board from the template, the automations are not enabled on the new board.  Is there a way to have the automations transfer to the new board?
Best,
Craig
2 accepted
Gaurav Kataria
February 10, 2025
Automations need to created for each board. You could use Automation libraries to share them https://support.atlassian.com/trello/docs/working-with-command-libraries/
ACE
February 10, 2025
As far as I know, in the list of rules, for each rule there is a button to add that rule to another board. I imagine you will have to do this from the template board for each of the rules. I don't know if it can be done with all of them at once...
Thank you.  Yes I've been doing it this way for years.  I thought I'd ask in case I was missing something  :)
Like ACE likes this
