Viewing and Exporting Labels
Angela Morrill
July 31, 2024
Hi, can someone tell me if there is a way to export labels from Trello? My team uses many labels, but I am finding it difficult to audit them to make sure there are no duplicates. I understand that it is easy to find duplicates if they are worded similarly, but if they are not worded similarly, duplication can occur. Also, when lots of labels are needed, editing the list can be tedious because there does not appear to be a "see all" function, and therefore I have to keep clicking "see more" until I get to the bottom of the list. Maybe there is a feature to see all the labels in one place and download them for review & auditing, yet I have not found it yet.
Thank you!
Alisson Sartor
August 2, 2024
Hello, Angela!
Welcome to the community,
Currently, Trello does not offer a feature to export labels. The number of labels you need to export isn't specified, but the best solution at the moment would be to handle this process manually. As for a feature that allows you to display all labels at once, this is a valuable suggestion, and I will recommend it to our team for future consideration.
Kind regards
Alisson
Trello Team
FREE
