Work space and templates
Milica Virag
August 14, 2025
How do I go back to templates if I already chose one? If I want to change it. Can I have more than one workspace?
NHMG
August 14, 2025
Templates are for new boards, so going 'back to templates' only implies
It's not like choosing a new 'skin' for an existing board if that's what you mean?
You can set up your own templates, whether starting from an empty board or reusing an existing one and choosing Make template in the board menu.
But any template will always work as templates do: you open it and it creates a 'copy' that you can then adjust.
As for more Workspaces, sure, no limitations there afaik, but note that on the Standard and Premium plans those are billed per Workspace per billable user.
