×Hello all,
I have an automation which sends the web request
/rest/api/2/user/search?query={{issue.customfield_12345.urlEncode}}
where {{issue.customfield.12345.urlEncode}} is an email address field. This works perfectly fine when using a testing account with a full access API token and returns results exactly as intended. I want to use a Atlassian Service account where API keys must be created with scopes, however I cannot get this API call to work when using an Atlassian Service account with the scopes listed in the Atlassian REST API documentation:
Permissions required: Browse users and groups global permission
Anonymous calls or calls by users without the required permission return empty search results.
Scopes
OAuth 2.0 scopes required:
Classic RECOMMENDED:read:jira-user
Granular:read:user:jira
,read:user.property:jira
,read:application-role:jira
,read:avatar:jira
,read:group:jira
I have confirmed that:
Unfortunately it simply doesn't return any results, which suggests that the permissions are somehow not correct.
If I change the only the Authorization header to use the known working test account API key, it works fine and returns results, but when I change it to the Service account key, it fails. I've even tried other permutations of scopes and app access but nothing appears to work.
Any ideas greatly appreciated!
Hi @Joe Johnson
When using an scoped APi token, you can call the app API directly.
You need to call the Atlassian API to use API tokens with scopes for Jira {{https://api.atlassian.com/ex/jira/{cloudId}}
See the documentation.What-are-scopes-for-API-tokens , in the section "Create an API token with scopes"
Ha! Thank you!
I actually came back here to say that I'm one step further; I found the docs above earlier and have changed the URL including the orgID etc, but now I get a 404 for that URL. I wondered if it was authentication related and I'm not sending the credentials in the correct way, but I would have expected a 403 in this case?
With PAT and Basic auth in the standard API calls, you need to encode the credentials:
service.account@domain.com:ATT123etc
as base64 and then pass them in the auth header as
Basic aBc123
How do you pass Bearer tokens? Do you need to encode as Base64 or just like
Bearer ATT123etc
The docs don't really make it clear.
Thanks again!
Hi @Joe Johnson
I think it's Bearer <PAT>
Thanks. I've tried every variation I can think of but I'm still getting a 404 which is very strange, and I've checked the CloudID which is also definitely correct.
Mystifying!
