Access forms smartvalues data
Mauricio Heberle
November 14, 2024
Hi everyone,
I'm following the documentation of this newly released feature, but I'm not being able to retrieve the data.
Forms uuid according to
https://developer.atlassian.com/cloud/forms/rest/api-group-forms-on-project/#api-project-projectidorkey-form-get
Forms fields:
In my automation rules, I tested the following syntaxes with no success:
Using manual trigger
{{issue.forms.0228c499-61f5-4cc3-959a-2253966f4792}}
Log Output :
f3e15d5b-efa2-4835-812f-96f728e1b8c5
Using forms submitted trigger
{{forms}}
Log Output:
Am I missing something?
Julian Governale
November 14, 2024
If JSM, you will need to set a field key value first in the form for each field and then use the smart values to retrieve the data. The smart value you are using is just to identify the form UUID, but won't export the data associated with it from my understanding.
Mauricio Heberle
November 16, 2024
Actually I found out that my problem was the trigger.
I was using "Froms trigger" by opening an already submitted form for customer editing and closing it again, which causes the automation rule to trigger. The rule is trigged normally, but nothing happens, then I created a brand new issue and it worked perfectly.
Like • Bill Sheboy likes this
November 14, 2024
Hi @Mauricio Heberle
Are you using a form in Jira Service Management?  That new form's smart value only applies for those types of projects / forms.
Although forms have recently been added for Jira Software Projects, I have seen posts from Atlassian team members that the smart values do not work for those forms yet.
Mauricio Heberle
November 15, 2024
Hi @Bill Sheboy Yes, it's being used in JSM.
