Action: "Organization" contains the list of contacts to add to the watchlist.
Expected behavior:
Adding "Organization1" to the service request, means all emails under "Organization1" will receive a notification when they are added, and they are able to view the request in Servicedesk portal.
I want to track the response for each organization, so each organization have to create a separate ticket.
In the parent issue I have a custom field "ListOfOrganistions" field which can contain multiple values. e.g. Organization1 Organization2 Organization3
On manual trigger of automation rule, the automation rule will clone for each organization. However, I am unable to assign Organization to Organizationid in the branch.
Advanced branching is used for this:
for each (organizationid){
Set Organization to {organizationid}
May I know how can perform the above bold logic in automation rule?
Hi @Jy
Whenever you ask for help with an Automation Rule it will help us to help you if you provide:
1. what type of project is this (e.g., company-managed, team-managed, etc.),
2. images that show your complete rule.
3. images showing the details of any relevant actions/conditions/branches.
4. images showing the Audit Log details for the rule execution.
5. Explain where the issue is.
These questions are not for not willing to help, but to have community members understand on how automation works.
Hello @Jy ,
By default 'Organization' field doesn't support smart values; you can use more action to add json.
In the below screenshot, I've looped through the organization list of issue (customfield 10002 is my organization field); and added the organization ID to via additional fields.
