Autofill Text Custom Field
Sagi Gueta
I'm trying to define an automation that will auto fill a regular text field ("Aha! Release Version") based on another version custom field ("Released Version").
I'm using as a set value the following smart value:
{{issue.fields.customfield_10206}}
but for some reason.. there is nothing going on. I've tried several other things that worked good for me in the past but nothing will do.
Do you have any idea what can possibly be the right method for that issue?
Thanks in advance :)
3 votes
Mikael Sandberg
You need to remove field from your smart value, it should look like this:
{{issue.customfield_10206}}
Sagi Gueta
October 3, 2022 edited
@Mikael Sandberg  Hey thanks for the idea!
It's works now - but still not as I've expected, as it shows the id of the version, instead of its name.. Is there any option to make it copy that value as it shown in released version?
Mikael Sandberg
Okay, so add .name to your smart value and that should give you the name.
Like • Sagi Gueta likes this
Sagi Gueta
Works great now :D
