Automation failiing when trying to update Asset~!
Randy Michel
The following objects weren't edited
Unable to update objects
This is the error I receive when trying to follow the steps provided : How to update user type attribute of an Asset objects using Automation after Import | Jira | Atlassian Documentation
I have add a screenshot of the automation. I have tried can it be the api? Screenshot 2025-04-23 120138.png
April 23, 2025
Hi @Randy Michel
There is an active incident impacting automation rules.  You may want to wait for that to clear and then try your rule again.
Please watch the incident here to see progress / updates: https://jira-software.status.atlassian.com/
Randy Michel
Hi Bill,
I doubt it as this issue has been happening for weeks.
I just chose to open a ticket today!
Randy Michel
April 23, 2025
Please post an image of your entire rule in one continuous image (for context) and an image of the audit log details showing the rule execution (with all of the areas at the right side of the log expanded).  Thanks!
Like • Valerie Knapp likes this
Randy Michel
April 23, 2025 edited
April 23, 2025
Please show the complete rule, and the audit log details for the rule execution
Those are needed to provide context for the symptom observed.  Thanks!
Randy Michel
Hi @Bill Sheboy
Unless im doing something that's the full automation rule. The trigger is a manual trigger which branches into an AQL. and that's the whole rule. Is there another view I should use?
April 23, 2025
The audit log you show is for a rule with a Scheduled Trigger, not a Manual one.  Let's assume the trigger is scheduled...
As your rule is slightly different that the knowledgebase article you are following, please post images of the following, as they will help to compare what the audit log shows:
  • an image of the Create Variable action for EMAIL
  • an image of the Create Variable action for AAIDUser
  • an image of the Edit Object Attributes action
In the meantime, you may also compare the name and case of the smart values: when smart values do not exactly match, they return as null, leading to unexpected results.
