×Hello,
I'd like to get some help with an automatic rules I'm trying to implement, hope you can help :) Here is the situation:
- I have a manual trigger in one of my project to create Enabler stories in ANOTHER project
- Those enabler stories are created in the project B and automatically linked to the original task/story/bugs etc. from project A with the mention "implements"
- On those enabler stories (from project B) I would like to add a condition to automatically add the Epic link and it should be the same epic link than the one from the project A
I hope it's clear :) Hopefully one of you could help me with that !
Thanks a lot anyways!
Hi @Audrey Artis -- Welcome to the Atlassian Community!
You are describing a case where you want to trigger a rule from one project, create a new issue, and link it to an epic in the original project. Is that correct?
If so, you definitely can do this with an automation rule. Because this rule touches multiple projects, it will need to be a global rule. There are limits on global rule execution counts so please check with your site admin for information.
Are you planning on executing this rule from the Epic or from a Story that is linked to the Epic?
For the first case, your rule would be something like this:
If you instead trigger the rule from a Story linked to the Epic, the rule would be:
Best regards,
Hey Bill,
I have already configured the first rule with the manual trigger.
The part I'm missing is the automation to add an epic link to the enabler story.
The epic link for the enabler story should be the same than the story that triggered the creation of the enabler.
Thanks for your help!
Hi Audrey,
Please try to set the Epic Link to the Current Issue when you create the new one.
If that works for you, please consider marking this question as answered. That will help others in the community find solutions to similar questions faster.
disregard this message, I resolved my issue
