×I'd like to count issues:
WHEN an issue transitions to In Progress
AND there are more than 8 issues already In Progress (count these)
THEN send a message
Should I be using this?
{{lookupIssues.size}} greater than 8
Hi @Fred
I cannot tell if you are on Server/Data Center or Cloud version, so...
Lookup Issues will work for Cloud version, so your check on the size can work with the JQL you supply.
For Server/Data Center, you may want to try a scheduled rule instead so you can check on {{issues.size}}
And regarding WIP measures, we also use automation to track Age of WIP. Here is a how-to for that rule.
Best regards,
Gotcha; Please try a rule like this to send a message when issues are moved into progress.
project = myProject AND statusCategory = "In Progress"
Please note: by design JQL lookups inside of rules exclude the trigger issue, so I lowered the condition value to 7 for the condition test.
Fred, I am glad to hear that helped.
Here is a related suggestion for improving WIP management that you may want to watch: https://jira.atlassian.com/browse/JSWCLOUD-21297
It's Jira Software, Cloud version.
I'm looking for a way to 'count' issues and not expressly finding it.
This....I've tried using the Jira javascript charts gadget, but the "Count of Issues" will not support a daily count between 2 different dates.
What it only ends up showing is how many things TRANSITION into a particular state (per the query), but it doesn't keep a count like a Cumulative Flow Diagram might demonstrate.
It's almost as if this "Daily WIP count" should be obvious, especially for those using Kanban or strictly flow-oriented process workflow.
