Can I use variables with the lookup table on Jira automation?
Christos Katsivas November 11, 2024
Hi all,
I am trying to create an automation, and I would like to use the lookup table.
I have created a smart value named "provider."
Can I use the value of this variable to retrieve the corresponding value from the table? For example, something like this: {{myTable.get({{provider}})}}
Thank you.
5 votes
November 11, 2024
Hi @Christos Katsivas -- Welcome to the Atlassian Community!
Yes, that is possible.
Once inside of the double-curly brackets for an expression, additional ones are not needed.  Please try this instead:
{{myTable.get(provider)}}
Thank you for your help!
Like Bill Sheboy likes this
November 11, 2024
Did that resolve this one for you?  If so, please consider marking this question as "answered" to help others with a similar need find solutions faster.  Thanks!
Like Christos Katsivas likes this
