I have seen article about JiRA integration qith UFT with Xray ,but couldnt find any information about UFT with BPT(business process testing)framework
Please checkout below link for complete solution:
https://qanovation.com/2020/04/03/uft-integration-with-xray-jira/
Developer from Atlassian here.
We don't have any deep integration with those particular third party tools.
Regarding integration we do have actions to make outgoing web requests, as well as listing to incoming web requests depending if the external tool can be setup in a way to send or receive data in the correct format. We've got a page that mentions third party integration on our support docs here: https://support.atlassian.com/jira-software-cloud/docs/what-third-party-applications-can-i-integrate-with/
There are a few articles that do mention using Xray with web requests such as here: https://confluence.xpand-it.com/display/XRAY360/Extending+and+integrating+with+Xray+using+Automation+for+Jira. But it's something you'd have to try and play around with.
If you require further help with your automation rules then you can contact Atlassian support for more details: http://support.atlassian.com/
I hope this helps.
