×Hi, friends! I have a problem again...
I have connected the screen to the transition (todo -> in_progress). This screen has only one field ("Assignee").
I need to create such a condition on this transition: a assignee must be assigned to make the transition. I don’t know how to do it.
I will be glad for your help and advice!
Hi @Nero Mars
You have to go to the workflow edition page. There, look for the transition that you need to edit (todo --> in progress) and use the "Validators" options. Should work for your need.
Regards.
