Hi, I'm wondering if its possible to attach a file from an issue on Jira to a page on confluence. I was thinking of using the web request action to send a request to the confluence API using something like
attachment: {{issue.attachment.content}}
in the custom data body. Would this even work? Is there an easier way of doing this?
Right now I have it so than whenever a worklog is created a PDF gets generated and attached to the issue. I need to then automate this PDF being uploaded to a confluence page.
Thanks.
Could you specify your whole use case in more details? What problem are you trying to solve?
What would be the trigger that should start your automation rule? Is there any special page you´d like to add the attachment? which attachment should be added? etc.
This helps the community to better understand your requirement and find a fitting solution.
Best
Stefan
thanks for the updated information. Where is the PDF generated and how does it get attached to the issue? Does this happen through an automation or manually?
Further question:
Please also add the hosting type (cloud or DC) so we can analyse this correctly
Best
Stefan
A PDF of the issue gets generated and then attached to said issue via automation. The hosting is cloud.
