Copy field priority from initiative to epic
Ori Lazar November 22, 2021 edited
HI
I am trying  to do automation in Jira cloud  that copy the value from "priority" field  in the initiative to the same field in the epic below the initiative.
parent = initiative
epic = child
thanks
Rick Olson
November 22, 2021
Are you trying to copy the priority field from the initiative to the epic when trying to add the epic, or when updating the initiative you want it to also update the epic?
November 22, 2021
Hi @Ori Lazar
Yes, and...to what Rick asks:
Or are you trying to do both?  That is, keep the Priority field in sync between an Initiative and its child Epics?
Like • Ori Lazar likes this
HI @Bill Sheboy  @Rick Olson
when updating the initiative I want it to also update all the epic's below it
thanks
Rick Olson
November 23, 2021
Ori Lazar November 23, 2021
Thanks I will try it
Becci Watson August 4, 2022
I tried it and it doesn't work
Carrol Patterson April 24, 2023
How do you do it the other way?
When creating a new epic, I want an automation rule to copy the parent initiative field values (wsjf fiields) down to the child epic just created.
April 24, 2023
