Copy fixVersion to a text field
Nofar Ben Kereth
I'm trying to copy the fixVersionto a text field (for an integration that doesn't work with fixVersion field).
I configured a pretty simple rule that indicate "success" when I run it but the text custom field isn't changing.
Screen Shot 2022-02-09 at 17.36.33.pngScreen Shot 2022-02-09 at 17.36.38.png
Alexis Robert
February 9, 2022
Hi @Nofar Ben Kereth ,
this is because the smart value for fixVersion is a list, so you can't juste use it like that.
If you want the versions name, you should use this :
{{issue.fixVersions.name}}
Let me know if this helps,
--Alexis
Nofar Ben Kereth
That worked thanks!!
