Dear Community,
I hope you all are doing well!!
I am an Jira site admin of Jira Cloud site of my organization. I have Created few labels for the automation and I have checked and implemented in few projects. Problem is that those created labels are visible to me only not for other Jira users.
I have implement an automation for - If the labels field contains value "Subtask_Tree" then create predefined sub-tasks list for the story issue types
I am able to use this automation in the respective projects, while the user of the respective projects are unable to find the label "Subtask_Tree"
As I know that labels have global scope, then why other team members are unable to use it.
Kindly suggest me the solution of the issue.
What is the symptom the other person is seeing that leads them to believe the label "Subtask_Tree" is not available.
Labels are shown / recommended in the field after they are first used. Has the label been used in your site yet?
Hi @Bill Sheboy
Thank you for your response. I'd like to inform you that these labels have been used in other testing projects in the same Jira instance by me (Admin).
I recall this symptom could occur if the user account did not have create / edit issue permission...although that seems unlikely for this case.
There was an defect a few years ago for this symptom, which was fixed by Atlassian: https://jira.atlassian.com/browse/JRACLOUD-74103
I recommend working with your Jira Site Admin to submit a ticket to Atlassian Support for their help. When you hear back from them, please post what you learn to benefit the community. https://support.atlassian.com/contact/#/
I am following up to learn if you checked with the Atlassian Support team for this issue.
