Custom field not recognized in Jira automation "additional fields"
Dave Vronay
November 18, 2022
Hi there,
I have a team-managed project.  On the epic, I have a custom field called "Design Reviewers".  When this field is changed, I want to update the custom field called "Reviewers" on any issue in that epic that is of issue type "design".
I can get all of the logic working, but when I try to update the field, it fails, saying that the field "Reviewers" does not exist.  Here is the JSON I am using:
"fields": {
"Reviewers": {{issue.epic.Discovery Reviewers.asJsonObjectArray("name")}} }
The error I get is
additional fields contains invalid field(s) in 'update' or 'fields" section
Reviewers
Any idea?  The Reviewers field is on the issue, and other automation is referencing it.
Alex Koxaras _Relational_
November 19, 2022
Hi @Dave Vronay and welcome to the community,
To be honest this rule was a real pain in the ***. It took me a solid 30 mins to figure this out. The json that worked for me was the following:
"fields": {
"Reviewer": {{issue.epic.Design Reviewer.asJsonObjectArray("accountId")}}
Of course modify the above fields to your likings. The whole rule was like this (I choose the trigger to be issue updated for my tests):
Let me know if that works out for you!
Dave Vronay
November 21, 2022
This works, but - for some unknown reason - it does NOT work if the field is called "Reviewers".  It works with any other name...
November 21, 2022
Whaaa??!?!?
You mean the plain reviewer or the design reviewer?
