Custom field update in Parent issue when there is change in Sub task using Automation rule
Sayi_Iynapurapu April 9, 2025
All,
I have a Sub task called Certification which is having a List Custom field (SOW). I would like to update SOW in Parent issue when there is an update for SOW in Sub task. Please advise to solve this.
Sayi
Izabela França
Hello, @Sayi_Iynapurapu ! I hope you are doing well.
You can create an automation with a Field value changed trigger that monitors changes to the List Custom field you need. And if any changes are made, it will trigger another action to copy the field from the subtask and enter it in the parent.
Here's an example of the automation that would work with the field description.
Let me know if helps :)
atlassian, opsgenie migration, jira service management, incident response, on‑call management, alerting tools, migration guide, devops operations, service reliability, atlassian learning, migration best practices, opsgenie support, IT operations
Join the Opsgenie Migration group 🚚
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗
