Disable notifications for specific request types
Kelly Phillips
I have an Issue Type called 'Joiners, Leavers, Movers'.  There are 4 Request Types linked to that issue Type: Joiners Leavers Movers, JLM Access, JLM Hardware, JLM Site Access.
Currently, reporters get email notifications for comments and status transitions for all of the above, which can sometimes mean a reporter is getting up to 20 emails a day as we work through the process of user onboarding etc.
I would like to change it so that reporters only receive emails for the 'Joiners, Leavers, Movers' request type, and not for the other JLM request types.
Any suggestions as to how I can set this up?
I tried to turn off all notifications, but then couldn't specify which issue types to send notifications for.
Emily _ DevSamurai
Hi @Kelly Phillips
To modify email notifications in JIRA for specific issue types or request types, you generally have to work with JIRA's notification scheme. However, JIRA's default notification scheme doesn't allow for granular control at the issue type level. Here are some suggestions:
  • Workflow Post-Functions: Customize the workflow of the 'Joiners, Leavers, Movers' issue type. Add post-functions in the workflow transitions to send custom notifications.
  • Silent Transitions: Implement silent transitions for certain issue types. This involves modifying the workflow to not send notifications for specific transitions.
  • User Preferences: Encourage users to adjust their own notification settings, although this is less effective for controlling notifications at scale.
  • Try Atlassian's plugin: As far as I understand, Asset Management for Jira - IT Assets & Licenses: JSM, ITSM can enhance your data tracking and management capabilities within JIRA. AssetIT allows you to customize detailed and clear permission schemes, as well as notification systems, which will be helpful in your case. Besides, AssetIT offers many features suitable for the HR area, ranging from Onboarding/Pre-Defined Kits to the Booking system and many more.
I hope this helps!
Kelly Phillips
Hi @Emily _ DevSamurai
Do you have more information on the silent transitions?  I can't do the workflow post function because it doesn't allow me to specify just the one issue type.  At least not that I can see (I am not a expert in Jira).
Kelly
Danielle Bonneau
Came across this when trying to do something similar (want to disable customer notification in a project for specific Request/Work type).  Any luck solving this?
I tried a from-scratch workflow thinking it was workflows that triggered the notifications but they all still fired.
Kelly Phillips
I'm still trying to resolve this.  Silent transitions don't exist in Jira Cloud (no logical).
You are also unable to delete or remove the post function from the workflow.  You can edit it, but it still requires you to select an Event.  And even when you create a custom event, it forces you to select a template which is linked to a notification scheme.
So you end up going round in circles with no solution.
