×Hi all
Just want to seek for advice.
We have a ticket getting created and the information in the description looks like below
----Example
Hi, I am requesting a laptop of contractor "John Smith". Their information is below. The start date is "10/14/2024". Can we get his laptop shipped out Today please as he starts Monday. Thank you
1. Contractor name: John Smith
2. Hiring Manager Name:Windows test
3. Contract start date: 10/14/2024 - end date:01/01/2025
4. Email: john.smith@testing.com
5. Phone: 111-111-1111
I want to extract the name of the hiring manager. if possible
thanks in advance
Gene
Hi @Gene Pengson ,
you can try to use Smart Values:
{{issue.description. substringBetween("Hiring Manager Name:", "\n")}}
This will extract text between Hiring Manager Name: and new line
You can use plenty of functions to extract the string. The ideal would be to create your issue using custom fields and providing specified value inside - even using API if needed.
To make it simpler I'd first split it by \n and then extract the value starting with some string:
You can try:
{{issue.description.split('\n').match("Manager Name:(.*)")}}
You can try different methods using another functions:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/
