Hi there!
I am trying to setup an automation, which parses github PR webhook payload, finds an issue based on this payload and comments under the issue that a PR is opened.
Unfortunately I am facing a problem with the JQL, because in order to get the issue key I need to extract if from the webhook payload.
Here is my JQL condition:
key = {{webhookData.pull_request.title.match(".*(RM-\d{4}).*")}}However, when the automation rule is executed, My JQL condition reports
"No issues were found, stopping the rule."
I found a super old bug about similar problem in AUT-516 and have tried the folowing options (none of them worked for me):
Here are some screenshots: &
I am sure that I overlook something and will need you help, community!
Best from me,
Dimitar
The answer to this it pretty straightforward. We have to use Incoming Webhook as a trigger with "Issues provided by running the following JQL search". Here is a screenshot of the working rule:
I do the same as suggested here but when the title does not contain an expected issue string like "RM-123", then the automation fails and send me an email.
Is there a way to set a default value if no issue string is found? Or another way to avoid an error for this situation?
Ok, I figured it out by myself.
I use the option "No issues from the webhook" in the "incoming webhook". Then I add the following steps to the automation:
1. "Create variable": This stores the extracted issue key from the pull request title into the smart value variable "issue".
2. "Advanced compare condition": This has the effect that if there was no issue key in the title of the pull request, I do not execute the next steps in this automation.
You are lucky - you are running on Cloud.
Atlassian appears to be holding off from implementing "Create Variable" in DC.
