I AM ON JIRA SERVER
I want to set the value of Target Start to be the present day, but this JSON is returning an error saying the value has to be a string. Anyone can help?
So... this may just not be possible:
As @John Funk wrote back in Nov 2020:
And @Bill Sheboy found:
According to this Code Barrel ticket, the Portfolio and Advanced Roadmap fields are not supported yet:
Alas, that Improvement request still appears to be open. :-{
Same ticket in Atlassian's system: https://jira.atlassian.com/browse/JIRAAUTOSERVER-159
I wrote a rule to update the target start when a ticket transitions from To Do -> In Progress, which works perfectly. Hooe this helps. Here's the custom JSON:
"fields": {
"Target start": "{{now.jiraDate}}"
Hello the attr for the field "Target date" is "customfield_11001" you can export to XML any Epic or Task and check this...
Also, it is a locked custom field. This custom field is created and required by Portfolio for Jira.
Looks like "Target Start" is just a date (without a timestamp)? Maybe try:
{{now.jiraDate}}
Some other functions you might try are here: https://confluence.atlassian.com/automation/date-and-time-functions-993924864.html
I just tried that and got the same error.
Here is the error I am receiving:
"(Operation value must be a string (customfield_14202))"
It would be helpful to do some debugging to see what an existing value looks like (to Automation).
So I would create a new rule with a Manual Trigger that doesn't do anything but do a Log action with a message of:
Target Start: {{issue.customfield_14202.value}}
And then manually trigger the rule from an issue that already has Target Start set, then look at the Audit log for this new rule to see what a "valid" value looks like.
I suppose you might also try:
{{now.toString}}
I tried that, and the Target Start is set on the ticket, but the audit log shows up empty. Photos attached.
I guess I would also try seeing if you get anything for these Smart Values:
{{issue.Target Start}}
{{issue.Target Start.value}}
{{issue."Target Start"}}
{{issue."Target Start".value}}
Oh and also: {{issue.customfield_14202}}
{{issue.customfield_14202}} worked and returned this value
2021-11-02
How do I take this information and move forward with configuring the automation
