I have a very simple workflow:
When: Value changes for - Smart Checklist Progress
If: Compare two values - {{issue.Smart Checklist Progress}} matches (^$|.*Done}
Then: here's where I need help
Transition the issue - Currently, I have selected Done however, what I would like is for the issue to transition to the next state in the workflow.
How would I go about accomplishing this task?
Hey Alec,
You will have to name the actual status you are transitioning to - you can't just say next step, because there might be multiple steps in some workflows.
Hello John, thank you for your reply.
Each status has its own name. Is there a way to check if the next transition in the workflow is 'Done'?
For instance, this workflow is linear and each status has to be transitioned to, the checklist is completed, and then the workflow is transitioned to the next status in the workflow.
Is there a way that I can add a comparator to check if the next workflow status is 'Done' or 'NameOfStatus'?
No, there is no concept of "next status" in automation, because again, a status might go to multiple statuses or there might be statuses with the All transition to them. It's not possible.
Is there something you would suggest that would better help me accomplish this task? My primary goal is to transition a task automatically through its workflow when all of the smart checklist tasks have been completed.
I would suggest you do a series of IF/THEN conditions:
IF status = BACKLOG then transition to In Progress
IF status = In Progress then transition to Test
Etc.
So I've now run into the issue where the issue only seems to transition a single time, even if the automation rule has multiple transitions.
I have if status = order computer && smart checklist = done then transition to setup account.
if status = setup account && smart checklist = done then transtion to configure system
if status = configure system && smart checklist = done
then transition to done.
However, I only ever get to the setup account status. Any ideas? Should I pose this as a new question?
I believe If the first check is met the rule will stop. As this is a checklist, the first check will be met each time. Try using branches for each as I believe they run separately.
Can you share the actual rule that you have so far?
If: Status is one of - Order Computer
And: Compare two values - {{issue.Smart Checklist Progress}} matches (^$|.*Done)
Then: Transition the issue to - Setup Accounts
If: Status is one of - Setup Accounts
Then: Transition the issue to - Configure Computer
If: Status is one of - Configure Computer
Then: Transition the issue to - Done
Can you share a screenshot of the actual rule?
You should use the IF/ELSE condition - Sorry for the confusion there.
It would look like this:
I'll give this a try and update! Thank you for the clarification.
edit: The IF/ELSE-IF clauses were the solution.
Yeah, that was my mistake in calling it IF/THEN off the top of my head - sorry about that again. This should do the trick for you.
@Alec Burton hey!
Check out our article about how to Transition an issue to the next state when all the checklist items are completed
However, you would still need to choose the "destination" status.
If you need more assistance from our team, feel free to reach out to smartchecklist@railsware.com.
Best regards,
Olena
Thanks for the reply! I had actually come across this article when I was first creating this automation rule and it helped me a lot.
However, the automation rule that I created became more complicated and I needed additional help.
Sorry, meant to answer in the thread above. Updated
